Image Widget
Image Widget
The Image widget provides the ability to present custom images in your dashboard. You can use it to present the logo of your company or customer, or anything else that helps the user to better visualize your application.
1. Image Behavior
Image behavior is where you get the image URL from, and it can be three types: static, conditional, and dynamic.
You can use TagoIO's file system to store the image, and cache the public URL.
1.1 Static
It displays the image from a static URL.
1.2 Conditional
Creates conditions, where each condition will have an image URL associated with it, and if the variable linked in the Data from field satisfies this condition, this image will be displayed.
1.3 Dynamic
This image URL comes from the variable data.
2. 'Data From' Field
The conditional and dynamic behavior has a Data from field to set the device and variable that will be used.
2.1 'Data From' for Normal Dashboards
2.2 'Data From' for Blueprint Dashboards
    • Note Widget
    • Image Marker Widget
      The image marker widget allows you to add pins to different images. You can also manipulate the colors, values, and icons for each pin. This widget also accepts features like metadata and series, that can be set in your variable data. Creating your ...
    • Widget Cache system
    • Adding Image Selector field on Forms
      The Image Selector field type allows you to put an entry where the user can select one or many images with given values. Users will need to click on an image and the value you entered in the widget options will be stored in your data device. The most ...
    • Compose Widget
