The trigger type Trigger by Resource allows you to execute your Action when a resource meets certain conditions. A resource is one of the following:
For example, you can trigger an Action when a new user sign up in your RUN or a new Device is added. This Action could push a notification to yourself.
After setting up the device, you should set a condition for your action to be executed. To do so, you must head over to the Trigger section.
You can set multiple conditions in an action, if at least one of them results in a match, the action will be executed.
The example above means that the action will be triggered when a Device with a tag key of tag_key and a tag value of tag_value is created.
