Keypad Widget
Keypad Widget
Keypad allows the user to submit a pin code along with an optional action string.
This widget is ideal to represent an alarm or to request a PIN code to unlock a resource.
Creating your own
To add it to your dashboard, choose the Keypad widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
2. Visualization
By default, the numeric keypad contains 10 digits that range from 0-9, and it also contains an asterisk (*) and a number sign (#).
You have the option to customize the content of the keypad by creating buttons that will appear along with the digits.
Example of custom buttons inside the Keypad
Learn more about the customization options of your keypad.
3. Data manipulation
The keypad will send the data immediately after pressing a custom button, or just by inputting a combination of numeric digits and waiting 3 seconds.
Whenever a PIN code is submitted, the structure sent to the variable will be:
DIGITS,ACTION
So, for instance, if the user has clicked the sequence 1234 and then DISARM, the output would be:
1234,disarm
Learn more about how to manipulate the keypad's data.
    • Keypad Visualization
      The numeric keypad contains 10 digits that range from 0-9, it also contains an asterisk (*) and a number sign (#). You have the option to customize the content of the keypad by creating buttons that will appear along with the digits. In the ...
    • Creating Keypad Widgets
      This article will demonstrate how to create a Keypad Widget using the TagoIO Node.js SDK. In order for you to create keypad widgets, this is the structure that you will need to send to the account.dashboards.widgets.create method. {   "analysis_run": ...
    • Keypad Data Manipulation
      The keypad will send the data by pressing a custom button or just by inputting a combination and waiting 3 seconds. Whenever a pin code is submitted, the structure sent to the variable will be: DIGITS,ACTION So, for instance, if your user has clicked ...
    • Widget Cache system
    • Custom Widget
