Keypad Data Manipulation
The keypad will send the data by pressing a custom button or just by inputting a combination and waiting 3 seconds.
Whenever a pin code is submitted, the structure sent to the variable will be:
DIGITS,ACTION
So, for instance, if your user has clicked the sequence 1234 and then a custom button DISARM, the output would be:
1234,disarm
If the user pressed a sequence and no action button, then the format will exclude the button, like so:
1234
Likewise, if the user only pressed a button and no sequence, this will be the format:
disarm
The best way for you to extract and use this data is through an analysis. The keypad widget offers an option to run an analysis in the User Control tab.
Analysis
If you select an analysis, this is the scope that you will receive when a user sends a sequence:
    "bucket": "5da07e1269c7ae001b2faefe"
    "origin": "5da07e1269c7ae001b2faeff",
    "id": "5da07e1269c7ae001b2faefs",
    "variable": "my_variable",
    "created_at": "2019-10-16T00:00:00Z",
    "time": "2019-10-16T00:00:00Z",
    "value": "1234,disarm"
Analyses are the best way to manipulate the data you receive from your keypad.
Since you can receive either a digit sequence, an action string, or both, the easiest way to extract the data inside of the analysis is by using the split string method.
Python
scope[0].value.split(',');
>> ['1234', 'disarm']
Node.js
>> ['1234', 'disarm']
Do not store data
If you select this option, the data sent by the widget will never reach the device's data storage. Keep in mind that the data sent will still be accessible inside of the analysis' scope.
Capture User Information
This option only works if you are using this widget inside of the Run platform.
If you select this option, the data sent by the widget will have any additional object called run_user. This will be the structure of the item:
  "variable": "run_user",
  "value": "5da07e1269c7ae001b2faeff"
The value in this case will be the ID of the run user.
    • Keypad Widget
      Keypad allows the user to submit a pin code along with an optional action string. This widget is ideal to represent an alarm or to request a PIN code to unlock a resource. Creating your own To add it to your dashboard, choose the Keypad widget from ...
    • Keypad Visualization
      The numeric keypad contains 10 digits that range from 0-9, it also contains an asterisk (*) and a number sign (#). You have the option to customize the content of the keypad by creating buttons that will appear along with the digits. In the ...
    • Creating Keypad Widgets
      This article will demonstrate how to create a Keypad Widget using the TagoIO Node.js SDK. In order for you to create keypad widgets, this is the structure that you will need to send to the account.dashboards.widgets.create method. {   "analysis_run": ...
    • Data Export
      At TagoIO, you have multiple options for exporting data. You can export device data directly from the Admin panel on your device's page, through the API, or directly from Widgets in either the Admin panel or the TagoRun portal. Exporting data will ...
    • Deleting Data
      When making a request to the TagoIO API, you must also specify the appropriate regional endpoint. Check out the available regions here: API documentation DEL - https://api.<region>.tago.io/data Headers: Authorization: Your device token. Optional ...
