Refund Policy
Refund Policy
If you have forgotten to cancel your plan or have decided to cancel it, you may be eligible to receive a refund. TagoIO offers refunds in certain situations.
In order to initiate the process, if you are entitled to the refund, follow the steps below:
  1. Downgrade your plan to a free plan to avoid any further charges
  2. Do not delete your account
  3. Open a ticket requesting a refund
When are you entitled to a refund
  1. You have been charged for your next month in the last 14 days and didn't have any services usage.  (no use of SMS, email, Data Input or Data Output during this period)
  2. You have been charged for your next year plan in the last 14 days (exclusive for yearly plans).
When a payment method different from Credit Card is used, there may be an additional bank and processing fee associated with the refund process.
    • Usage Policy
      When executing API requests to TagoIO by posting (data input) or to getting (data output) data, your account may face a limit policy based on the limits defined by you in the My Billing settings. The limits are based on the number of transactions ...
    • Downgrading Plans & Services
      You can schedule downgrades in your account for your plan, service limits, and add-ons. If you change your mind any time before the end of the billing cycle, you can modify or cancel the downgrade. All downgrades are only effective at the next ...
    • Analysis Overview
    • Sharing Dashboards
      A great feature from TagoIO is its native sharing capability for dashboards, because we know that sometimes a dashboard can become an entire feature that you want to share. If you want to share only the template of your dashboards, use the Distribute ...
    • Secrets
      Secrets are encrypted environment variables that can be used to store sensitive information, such as passwords and API keys. You set a key and a value for your secret: the key serves as the name of the secret, while the value contains your sensitive ...
