Icons Widget
Icons Widget
With icons, the user can create very personalized widgets for their applications, and the result can look like the ones shown below, but the possibilities are endless.
Users can add up to 9 variables in this widget, and each variable will show its last value.
Creating your own
To add it to your dashboard, choose the Icon widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
2. Conditions
The widget changes its content based on two types of conditions, Icon conditions and Color conditions, based on variable data. If it satisfies any condition set, then it will change the color of the content.
The priority order between conditions is top to bottom. A condition in the top row will always have priority over a condition in the bottom row.
It is possible to show your own images in the widget, by adding their own icon URL.
    • Widget Cache system
    • Map Widget
    • Compose Widget
    • Dashboard icons
      You can customize the looks of your dashboard by adding icons to it. The icons are displayed on the left side of your dashboard. The colors are totally customizable, and there are more than 100 free icons available for you to use. To add an icon to ...
    • Dynamic Table Widget
      Dynamic tables are tables that dynamically populate as your data arrive while keeping the history of the previous data in each row. Editing the dynamic table It is possible to customize widget color, apply a formula to columns, show time column, show ...
