Grain Bin Widget
Grain Bin Widget
The Grain bin widget produces a grain bin illustration, so you can easily track your variable information
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Grain bin widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
    • Widget Cache system
    • Custom Widget
    • Compose Widget
    • Map Widget
    • Note Widget
