Vertical Column Widget
Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, decide if they're to be stacked or not, and more.
This widget also accepts features like metadata and series, that can be set in your variable data.
1. 'Data From' Field
2. Composing X-axis and Y-axis
In the vertical column chart widget, it is possible to customize how the data will be displayed in the horizontal and vertical axis.
2.1 X-axis
By default, the X-axis of the chart will be the time of the values, and you can customize the range of time. But sometimes you need to group your data through the X-axis, even if they don't have the same time. To achieve this, you need to select a variable that contains the group and all data will be grouped by series.
Data is ordered by time ascending, but it is possible to change it to series
It is also possible to define the X-axis time range dynamically, using another variable data to achieve this. The variable data should look like the following payload:
  "variable": "time_range",
  "value": "Any value",
  "metadata": {
    "start_date": "2021-06-17T00:00:00.000Z",
    "end_date": "2021-06-18T00:00:00.000Z"
The  start_date  specifies the start of the range, and the  end_date  specifies the end of the range. In this case, the date and format should be in the ISO 8601 format.
2.2 Y-axis
In the vertical axis, it is possible to customize the scaling behavior, as it is possible to apply metric prefixes and abbreviations, change the step value (represents the difference between each tick), and more.
The Y-axis will automatically find the best scale for your data; it is not necessary to customize it, unless you want to.
You can set multiple Y-axis to your chart. Read more about Multiple Axes in Chart Widgets.
3. Filtering data
It is possible to pre-set some date filters to be displayed, and these filters can be in minutes, hours, days, weeks, months, or custom by choosing a date in the calendar.
4. Increasing performance
When a chart has a large number of data, it is possible to increase the widget performance by enabling the Downsampling feature. In addition, Downsampling makes the data easier to visualize.
Downsampling has two concepts, the Threshold and the Factor. The Threshold limits the amount of data to start the downsampling, and the factor is used to determine how many samples will be cut.
The greater the factor the greater the performance, but as the factor increases, the data also becomes less and less recognizable
    • Widget Cache system
    • Multiple Charts Widget
      Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, customize the line shape (step and smooth), decide if they're to be stacked or not, and more. In a multiple charts, each ...
    • Dynamic Table Widget
      Dynamic tables are tables that dynamically populate as your data arrive while keeping the history of the previous data in each row. Editing the dynamic table It is possible to customize widget color, apply a formula to columns, show time column, show ...
    • Entity Table Widget
      The Entity Table widget enables you to display data in a tabular format using fields from your Entities. Unlike the Static and Dynamic Table widgets, it does not utilize data from Devices. This widget lets you incorporate data from one or more ...
    • Static Table Widget
      Static tables are tables where each cell represents a different piece of information, and it can either be fixed text or data from a variable. Editing the static table It is possible to customize widget color, apply a formula to a cell, edit options, ...
