The Input control allows users to submit values to variables through a form.
The Input control is a very dynamic widget, as you can customize its colors, layout, text, and even icons.
To edit a specific section of this widget, you must hover over the desired element and click it. Promptly, a new page will appear on the right side with all the editable options for the selected element.
This widget works for both dashboards, Normal and Blueprint.
Sections are the main structure of the form, and each section has its own fields.
It is possible to show a divider between sections, duplicate sections, remove the captions, and more.
Fields are associated with a variable and device using the Data From. Once the field is submitted, the data can be sent through the bucket.
It is possible to select an analysis for each field, and when this field is submitted, it will run the analysis
This field is dependent on the type of dashboard you are using; the difference is explained below.
From the option 'Data From' on the right menu, add the Blueprint device and input the name of the variable that contains the information.
When using a Blueprint dashboard, the field Variable will not list variables to be picked because it doesn't know the devices linked to your Blueprint Device.
Input control has two types of fields: Switch and Text. Different from the Input Form, each field has a button to send data.
The switch type displays a simple button that changes the value of the variable to true or false.
In this type of field, there is the possibility to modify the true and false text to anything you would like.
A typical text input will be displayed, and the value will be anything that was typed into it
