Semi Donut Widget
Semi Donut Widget
Using data from multiples variables, the Semi donut widget automatically produces a Semi donut Chart, where each slice represents variable data.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Semi donut widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
    • Semi Pie Widget
      Using data from multiples variables, the Semi Pie widget automatically produces a Semi Pie Chart, where each slice represents variable data. This widget also accepts features like metadata, that can be set in your variable data. Creating your own To ...
    • Widget Cache system
    • Custom Widget
    • Compose Widget
    • Map Widget
