Semi Pie Widget
Semi Pie Widget
Using data from multiples variables, the Semi Pie widget automatically produces a Semi Pie Chart, where each slice represents variable data.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Semi pie widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
This widget works for both dashboards, Normal and Blueprint
1. 'Data From' Field
    • Pie Widget
      Using data from multiples variables, the Pie widget automatically produces a Pie Chart, where each slice represents variable data. This widget also accepts features like metadata, that can be set in your variable data. Creating your own To add it to ...
    • Semi Donut Widget
      Using data from multiples variables, the Semi donut widget automatically produces a Semi donut Chart, where each slice represents variable data. This widget also accepts features like metadata, that can be set in your variable data. Creating your own ...
    • Widget Cache system
    • Static Table Widget
      Static tables are tables where each cell represents a different piece of information, and it can either be fixed text or data from a variable. Editing the static table It is possible to customize widget color, apply a formula to a cell, edit options, ...
    • Device List Widget
      The Device List widget is a table that dynamically populates with information about your devices, such as names, tags, configuration parameters, and IDs. It can't access devices' data, however. 1. Editing the device list It works as a dynamic table, ...
