Cylinder Widget
Cylinder Widget
Cylinders are one of the simplest and most useful widgets. They make it easy to visualize the values relative to a defined range (with maximum and minimum limits) in a cylinder gauge.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Cylinder widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
2. Level labels
Level labels are dashed lines that can represent limits or divisions in your cylinder. It can be dynamically assigned by variable data.
    • Widget Cache system
    • Custom Widget
    • Note Widget
    • Compose Widget
    • Map Widget
