VU Meter Widget
VU Meter Widget
VU Meter gauges display the variable in a velocimeter gauge.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the VU Meter widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
This widget works for both dashboards, Normal and Blueprint
1. 'Data From' Field
    • Widget Cache system
    • Custom Widget
    • Angular Widget
      Angular gauges allow you to display your variable in an angular gauge meter. This widget also accepts features like metadata, that can be set in your variable data. Creating your own To add it to your dashboard, choose the Angular widget from the ...
    • Solid Widget
      Solid gauges allow you to display your variable in a solid gauge meter. This widget also accepts features like metadata, that can be set in your variable data. Creating your own To add it to your dashboard, choose the Solid widget from the list and ...
    • Compose Widget
