Clock Widget
Clock Widget
Clock gauges allow you to visualize the time in a certain timezone. You can see the timezone, weekday, hour, minutes and seconds.
The outer circle contains 60 dots, with each one representing a second. When all of the dots turn blue, it means that a minute has passed.
After a full minute, the dots will be reset back to empty.
Time format
This widget will either display the 24-hour or the 12-hour format, based on your account's preferences.
Timezone
By default, the clock will display the timezone set in your account. To change to a different timezone, head over to the Timezone tab of your widget and set a new one there.
    • Widget Cache system
    • Step Button Widget
      Step button allows users to increase and decrease values of a number or clock by using the (-) and (+) buttons. You can also define values for the incremental step and the limits. Creating your own To add it to your dashboard, choose the Step button ...
    • Custom Widget
    • Note Widget
    • Compose Widget
