DEL - https://api.tago.io/data
Headers:
Authorization: Your device token.
Optional Query Strings
KEY | TYPE | DESCRIPTION |
query | string | pre-defined by Tago |
qty | string | Maximum number of data to be returned |
start_date | string | Start date |
end_date | string | end date |
variable | string | Filter by Variable |
To delete data, TagoIO uses the same query string used to get data, for more details about each query, see here.
Below, we will show some examples of DELETING data using query string.
Deleting the last 99 items from the variable temperature.https://api.tago.io/data?variable=temperature&qty=99
Tip: Make sure your request is DELETE and not POST when trying to delete items. Note that posting data is relatively instantaneous while deleting data can take between 10 and 30 seconds to complete.
Deleting the last item from the variable temperature. https://api.tago.io/data?variable=temperature&query=last_item
Deleting the last value from the variable temperature (requires the 'value' attribute on the variable object).https://api.tago.io/data?variable=temperature&query=last_value
Deleting the last location from the variable temperature (requires 'location' attribute on the variable object).https://api.tago.io/data?variable=temperature&query=last_location
Deleting by period.https://api.tago.io/data?variable=temperature&start_date=2014-12-25&end_date=2014-12-26
Deleting the last value from an array of variables.https://api.tago.io/data?variable[]=temperature&variable[]=pressure&query=last_value
Devices can only delete their own data.
This means that if have multiple devices in a bucket, and you create data from a device, other devices cannot delete that data.
