Note Widget
Note Widget
Note allows you to create a text to be viewed in your dashboard. It accepts a markdown formatted text, allowing you to use bold, italic and list tools.
Although you could use the Note Widget to add images to your dashboard, we highly recommend that you use the Image Widget instead as it contains an auto resize image feature.
    • Widget Cache system
    • Compose Widget
    • Map Widget
    • Image Marker Widget
      The image marker widget allows you to place pins on various images, with the option to customize each pin’s color, value, and icon. This widget also accepts features like metadata and groups, that can be set in your variable data to alter how the ...
    • User List Widget
      The User List widget is a table that dynamically populates with information about your users, such as names, tags, email, and IDs. 1. Editing the user list It works as a dynamic table, as you can customize its colors, columns, and filter which user ...
