Markdown Guide
Markdown Guide
Emphasis
**bold**
*italics*
~~strikethrough~~
Headers
# Big header
## Medium header
### Small header
#### Tiny header
Lists
* Generic list item
* Generic list item
* Generic list item
1. Numbered list item
2. Numbered list item
3. Numbered list item
Links
[Text to display](http://www.example.com)
Quotes
> This is a quote.
> It can span multiple lines!
Images   Need to upload an image? TagoIO Files has a great interface.
![](http://www.example.com/image.jpg)
Tables
| Column 1 | Column 2 | Column 3 |
| John     | Doe      | Male     |
| Mary     | Smith    | Female   |
Or without aligning the columns...
| John | Doe | Male |
Displaying code
`var example = "hello!";`
Or spanning multiple lines...
alert(example);
Provided by EasyMDE
    • Note Widget
    • Building your own parser
      In this tutorial, you will learn how to convert (parse) a raw payload sent by a device into actual measurable variables.  Data flow structure You can create parses for devices that weren't found in our list of Devices, so that you had to use a ...
    • Everynet LoRaWAN
    • Field Types for Input Form
      The field is the structure that contains the relation between the inputted data and the Device data in some widgets. Fields can have a bunch of types, depending on the widget that it is dealing with. 1. Text A typical text input will appear, and the ...
