Display Widget
Display Widget
Display is a widget that displays the last value of a variable, regardless of the format of the value (string or number).
You can pick the variables, and each one of them will have its own box as well as simultaneously having the values shown.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Display widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
This field allows you to set the device and variable that will be used in this widget. Here you can choose to display data from a Device or an Entity.
From the option 'Data From' on the right menu, select one device or an entity from your list and the variable that contains the data.
From the option 'Data From' on the right menu, add a Blueprint Device or Entity and input the name of the variable that contains the information.
When using a Blueprint dashboard, the field Variable will not list variables to be picked because it doesn't know the devices linked to your Blueprint.
    • Widget Cache system
    • Custom Widget Parameters
      Parameters allow you to send a list of keys and values to your custom widget. One use of these parameters is to change the way your code behaves. You can have two widgets pointing to the same link, but exhibiting different behaviors. Each parameter ...
    • Clock Widget
      Clock gauges allow you to visualize the time in a certain timezone. You can see the timezone, weekday, hour, minutes and seconds. The outer circle contains 60 dots, with each one representing a second. When all of the dots turn blue, it means that a ...
    • Widget Header
      The widget header enables you to add customized buttons in the header of your widget in order to improve the flow of your dashboard. The widget header is enabled for all widgets. You can configure it by selecting the Header tab in your widget ...
    • Angular Widget
      Angular gauges allow you to display your variable in an angular gauge meter. This widget also accepts features like metadata, that can be set in your variable data. Creating your own To add it to your dashboard, choose the Angular widget from the ...
