Push Button Widget
Push Button Widget
Push button allows users to select options for different states, similar to a mechanical switch. Developers can configure text or an icon for each status, and associate colors to it.
You can also define an Analysis (scripts) to run when users change each state.
This widget also accepts features like metadata,  that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Push button widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
2. Push Button Type
The Push button can be configured in two different modes.
2.1. Mono-Stable
In this mode, the button will be presented in the default state at all times unless the user clicks on it. When a user clicks on the button, it will change to the temporary state for a couple of seconds, and then it will return to the default state.
You can select the colors, text, and icons for each state, and define an analysis to run in the temporary state [optional].
2.2. Bi-Stable
On the other hand, the Bi-stable type keeps the state that the user selected indefinitely.
You can select the colors, texts or icons for the buttons, and define an analysis to run in each state [optional].
3. Color from Metadata
You can control the colors of the Button widget by using information stored in the metadata of the variable.
For this, you need to switch the option present on the Visualization tab, 'Override colors with the conditions define here' to False.
Inside the metadata, the following fields can be used to define the color of each component:
"text_color"color for the text (value)
"button_color"color for the button
Here's a JSON example:
  "variable": "set_point",
  "value": 5.3,
  "unit": "°C",
  "metadata": {
    "text_color": "white",
    "button_color": "blue"
TIPYou can always enter colors using #HEX or RGB values instead of a color name.
  "value": 5.3,
  "unit": "°C",
  "metadata": {
    "text_color": "#FFFFFF",
    "button_color": "rgb(44, 144, 223)"
    • Step Button Widget
      Step button allows users to increase and decrease values of a number or clock by using the (-) and (+) buttons. You can also define values for the incremental step and the limits. Creating your own To add it to your dashboard, choose the Step button ...
    • Widget Cache system
    • Widget Header
      The widget header enables you to add customized buttons in the header of your widget in order to improve the flow of your dashboard. The widget header is enabled for all widgets. You can configure it by selecting the Header tab in your widget ...
    • Map Widget
    • Compose Widget
