Resetting My Password
On the signup page, click on the Forgot your password? link and enter your email, and we'll send you instructions to reset your password.
Want to change your password?
To change your existing password, go to My Account, select the tab 'Account Settings'  and click on the Change your password button.
The instructions here are to reset your credentials at the TagoIO admin, if you are looking for a reset/change password for you or your users for the TagoRun application, you need to access the User Management.
    • Profiles
      Profiles are similar to having different sub-accounts under your own main account. You can create multiple profiles for persons or organizations and then share them with others. By doing this, you will continue to own the 'sub-account' while allowing ...
    • Defining Actions
      Actions are initiated based on specific conditions and can execute a variety of tasks. The first step in configuring an Action is to specify the desired action. Below are the different types of actions available: Push Notification to myself This ...
    • Two-factor Authentication (2FA)
      Two-factor authentication (2FA) adds an additional layer of security to your account by requiring more than just a password to sign in. It requires and provides another form of authentication that only you know or have access to. This form of ...
    • Orbiwise LoRaWAN™
      This tutorial provides a step-by-step guide to integrate Orbiwise LoRaWAN™ with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
    • User List Widget
      The User List widget is a table that dynamically populates with information about your users, such as names, tags, email, and IDs. 1. Editing the user list It works as a dynamic table, as you can customize its colors, columns, and filter which user ...
