SenRa Network
SenRa Network
Using this article, the user will learn how to integrate a LoRaWan device with SenRa Network and Tago.
This setup is for the uplink operation: data sent from the device to your TagoIO account.
The integration is accomplished in two parts:
1) TagoIO Setup
First, go to devices section, search for SenRa and select it. Type a name for your device, and click on 'create device'.
Now, access the device that was created, go to the 'Token' tab, and copy the device-token to use it in the next step.
You should not create Authorization when integrating with Senra. Use the device-token instead.
2) SenRa Portal Setup
Now, log in to SenRa portal and go to your devices.
Choose the device to connect to TagoIO and click on the gear icon.
Go to Notification Target.
Make sure the status is Enabled, select TagoIO on the 'forward to' field, and paste your token in the 'device-token' field.
Now you are all set, every time your device sends data to SenRa, your data will be available at TagoIO.
    • Network Integration
      Your devices can always connect directly with TagoIO API using HTTPS or MQTT protocol. But, you can also connect them using different protocols to databases and web services by using one of this methods: Create a script that initiate access to ...
    • Senet Network
      Using this article, the user will learn how to integrate a LoRaWan device with Senet Network and TagoIO. This setup is for the uplink operation: data sent from the device to your TagoIO account. The integration is accomplished in two parts: 1) TagoIO ...
    • Creating a Network integration
      To create a new integration you must go to the Network management page and press the following buttonon the right side of the page. You only need to specify the network's name. Once you have the network created, you have several parameters that you ...
    • The Things Network LoRaWAN™
      This tutorial provides a step-by-step guide to integrate The Things Network (TTN) with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the ...
    • Connecting your MQTT Broker to TagoIO
      TagoIO supports MQTT connections through our MQTT Relay command-line tool. This software acts as a bridge between your MQTT Broker and the TagoIO platform, facilitating seamless integration and data flow. Developed in Rust, the TagoIO MQTT Relay is ...
