Displaying Locations on a Map with TTN LoRaWAN
If you have a custom payload format decoder at TTN (The Things Network), you can send your payload variables directly to TagoIO.
To display locations on a Map, your data needs to be sent inside the "location" field with the format shown below:
  "variable": "speed",
  "value": 10,
  "location": {
    "lat": 42.2974279,
    "lng": -85.628292
TagoIO converts the latitude and longitude fields to the specific format so you don't have to worry about any conversions. In order to accomplish that, you only need to have the variables latitude and longitude or lat and lng, and TagoIO will automatically get these values variables and create a new variable called location.
After you get your device to send the latitude and longitude information to TagoIO, create a dashboard and add a Map widget.  Look for the device, and add the variable 'location' inside the map.
    • Map Widget
    • The Things Network LoRaWAN™
      This tutorial provides a step-by-step guide to integrate The Things Network (TTN) with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the ...
    • Adeunis with LoRaWAN™
      TagoIO supports most Adeunis devices by providing the perfect integration with several LoRaWAN™ networks. It also parses the data by extracting the value of the measured variables in real-time.  All data sent by your device will be readily available ...
    • Map filters
      You can filter the results being displayed in a map in order to minimize the amount of information shown, allowing you to find exactly what you are looking for.  1. Filter using pins' data In the widget's configuration, in Filter options, you can ...
