The Map Widget allows you to visualize the location variables of your device on a map, as well as customize the visualization in many ways. By default, the map widget uses OpenStreetMap as provider; however, you can integrate your preferred map provider like Mapbox, Google Maps, or Here to fit your needs.
Additionally, the widget allows you to customize the visualization by adding icons, pins, images, links, geofences, filters, and much more!
The variable data should look like the following payload. Note that the 'lat' and 'lng' values should be added inside the 'location' field as shown below:
{ "variable": "location", "value": "My Address", "location": { "lat": 42.2974279, "lng": -85.628292 } }
This widget also accepts features like metadata and series, that can be set in your variable data.
To add it to your dashboard, choose the Map widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
This widget works for both dashboards, Normal and Blueprint.
Click on the cog icon to edit specific options for this variable, such as: pin icon, formulas, and more. Click on the close icon to remove this variable from the widget's data.
This field is dependent on the type of dashboard you are using; the difference is explained below.
From the option 'Data From' on the right menu, select one device from your list of devices and the variable that contains the location data.
From the option 'Data From' on the right menu, add the Blueprint device and input the name of the variable that contains the location information.
When using a Blueprint dashboard, the field Variable will not list variables to be picked because it doesn't know the devices linked to your Blueprint Device.
Present more information with an infobox that'll automatically be associated with the pins, and customize it with icons, images, external links, street views, formulas, routes by GoogleMaps, and much more.
In the widget edit screen, you can customize the following options for the variables:
Also, you can customize an image and a link that could be set through the edit screen or by metadata. In this widget, metadata always has priority over options set by the edit screen.
In addition, the map widget supports series, so you can group your variables' data in the same infobox.
If a group of variables has more than one external link or location data, only one will be considered based on the Data From field's order. This does not apply to images, as more than one image will produce a slide show inside the infobox.
The filter makes your data easier to visualize by allowing users to filter for results.
You can filter pins by device, variable, value, and time. Filters also provide a table to list each pin that's being displayed, and you can click on a row to center it.
Learn more about Map filters.
Draw colored geographic boundaries to make it easy to see your devices' trajectory through a zone.
You can draw polygon or circle figures and associate them with events, and build an analysis to receive notifications when the device enters or leaves the zone.
Learn more about Geofence in map widgets.
Customize your Map with GeoJSON or Shapefiles layers. Display boundaries, areas, roads, pipelines, and more. Learn more about Map Layer GIS.
