Language Preferences
The TagoIO admin that is used for the development of applications is displayed only in English. However, users that access your RUN application can visualize in any language that you set in your Dictionary. These end-users are also called 'RUN users'.
Some of the most used languages are:
  • English
  • Spanish
  • German
  • French
  • Italian
  • Japanese
  • Portuguese
All end-users will be able to select their preferred language from the tab 'Visualization Preferences' under the Account Setting page.
Make sure that your current plan allows the deployment of multi-language for your end-users.
    • Editing Accounts Details
      To manage details of your account, just click on the top-right menu and select the option My Account. From there, you can edit your name, phone, email address, company name, time zone, language, decimal separator, notification preferences and more. ...
    • Formula
      The Formula feature enables users to modify the visualization of data in specific widgets. Located inside the configuration tab of most widgets, the Formula can be applied to all fields of a stored register, including variable, value, unit, series, ...
    • Creating Analysis
    • Clock Widget
      Clock gauges allow you to visualize the time in a certain timezone. You can see the timezone, weekday, hour, minutes and seconds. The outer circle contains 60 dots, with each one representing a second. When all of the dots turn blue, it means that a ...
    • Analysis Overview
