TagoRun domain is changing
Greetings everyone,
We are transitioning the default TagoRUN domain from .run.tago.io to .tago.run. We believe this change will provide a better overall user experience, by making the domain names more straightforward.
All the RUN pages in the TagoIO portal will show the new domain tago.run, as the image below shows.
The new domain will be effective on Jan 24, 2023.
The old domain, run.tago.io, is deprecated, but it will be supported normally through automatic redirection.
Thank you for using TagoRUN.
