New improvements released to Entity
Hi Everyone!
We're excited to announce two powerful updates to our Entity feature, making your data management more dynamic and interactive!
New Input Form Widget with Entity Data Integration
Our Input Form Widget now directly connects with your Entity data, allowing you to:
  1. Modify Entity values directly from your dashboard
  2. Apply formulas to transform your data on the fly
  3. Create interactive forms that read from and write to your Entity tables
  4. And much more.
Setting this up is simple - just select "Entity" as your data source when configuring your input form fields. This creates a seamless connection between your forms and your structured data tables.
Real-Time Entity Updates on Dashboards
We've also improved how your dashboards interact with Entity changes:
When you select a different Entity in your Blueprint Dashboard, your dashboard automatically updates to reflect the new data.
  1. All connected widgets instantly display the current Entity information.
  2. Changes propagate in real-time across your entire dashboard.
These improvements create a more responsive experience, ensuring your dashboards always display the most current data from your selected Entity.
