Each time a push notification message is sent by an Action or Analysis function, it is counted as one Notification unit sent.
The service limit defined inside each Profile determines the maximum number of Notifications that can be sent during a one-month period (based on your billing cycle).
Each push notification is limited to 140 characters. The messages will be shown in the mobile app and browser when the end-users receive notifications through your RUN application.
If the Notification service limit is exceeded, no notifications in that Profile will be sent until the limit is increased or the billing period ends.
Notifications sent to your admin account (admin.tago.io) are free and not considered in your monthly usage.
Push notifications not used during the period will not be carried over to the next month.
More information about pricing and FAQ can be found on our
Pricing Page.
Related Articles
Notification
TagoIO will notify you when something needs your attention. You may need to perform an action depending on the type of notification. There are 4 (four) types of notifications: Applications - sent by a customized script that was triggered by the ...
SMS Service
Each time an SMS message is successfully sent by an Action or Analysis function, it is counted as one SMS unit sent. The service limit defined inside each Profile determines the maximum number of SMS that can be sent during a one month period (based ...
File storage service
You can use our Files module to store any type of files for reports, videos, logos, background images, and more. The File service is measured by the overall size of all files stored in your profiles. If any of your profile reaches the limit of size ...
E-mail Service
Each time an Email is successfully sent by the Action or Analysis function, it is counted as one unit sent. This limit will define the maximum number of Emails that can be sent from that Profile during a one month period. If this limit is exceeded, ...
PDF Service Generator
Learn how to create PDF documents using the TagoIO service generator. Simply make an HTTP request to our PDF service, and the response will be a base64. The base64 response can be sent by email using Analysis or it may be saved in our Files. POST ...
