How it works
How it works
There are a few things that you need to know about how TagoIO works in order to optimize your applications.
Watch this short video to learn about the concepts around devices, and tokens.
    • Note Widget
    • Building your own parser
      In this tutorial, you will learn how to convert (parse) a raw payload sent by a device into actual measurable variables.  Data flow structure You can create parses for devices that weren't found in our list of Devices, so that you had to use a ...
    • Blueprint Dashboard
      Blueprint is a type of Dashboard that allows users to dynamically link widgets to multiple devices. This type of dashboard is extremely useful when scaling up applications. Concepts Blueprint works by allowing users to change the widgets' devices in ...
    • Custom Widget Parameters
      Parameters allow you to send a list of keys and values to your custom widget. One use of these parameters is to change the way your code behaves. You can have two widgets pointing to the same link, but exhibiting different behaviors. Each parameter ...
    • Clock Widget
      Clock gauges allow you to visualize the time in a certain timezone. You can see the timezone, weekday, hour, minutes and seconds. The outer circle contains 60 dots, with each one representing a second. When all of the dots turn blue, it means that a ...
