Middleware
Middleware
Through a TagoIO middleware, companies can connect devices using their own protocol. The middleware acts as a protocol converter from any type (TCP/IP, UDP, ...) to the standard TagoIO APIs.
For more information on how middleware is done, check our documentation about Creating a Networks Integration.
Also, check our tutorial to get your network up and running available in our community.
    • Network Integration
      Your devices can always connect directly with TagoIO API using HTTPS or MQTT protocol. But, you can also connect them using different protocols to databases and web services by using one of this methods: Create a script that initiate access to ...
    • Sending Data to Device
      TagoIO supports two-way communication with all your devices so that it can send and receive data. There are some options for you to send data from your application to the device. Among the methods, you can use: Publish to MQTT Post data to a ...
    • Queclink GPS
      Queclink GPS can be integrated with TagoIO through the middleware that translates the devices TCP/IP protocol. The middleware allows uplink communication between the device and TagoIO while parsing the messages in order to extract commands and ...
    • Adding devices with connectors
      Connectors enables you to create a device with built-in behaviors that allow it to communicate with a Network very easily. When creating devices at TagoIO, it is important to know that there are different ways to allow them to send & receive data ...
    • Loriot LoRaWAN
      This tutorial provides a step-by-step guide to integrate Loriot LoRaWANTM with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
