Deleting Your Account
If you need to cancel your account, go to 'Account Settings' by accessing My Account.
Then, within the tab 'More', you will find the 'delete my account' button.
We will delete your account, including all your profiles, and then we will confirm by email when it is done.
Have in mind that all applications and data will be deleted. There is no way back :-/
Note: If you need to delete only one organization or customer to connect to a Profile, just request the cancellation of that profile by accessing the tab 'More' inside the Profile.
    • Deleting Data
      When making a request to the TagoIO API, you must also specify the appropriate regional endpoint. Check out the available regions here: API documentation DEL - https://api.<region>.tago.io/data Headers: Authorization: Your device token. Optional ...
    • Account Token
      The secret key used between Tago and external applications are Account Tokens. Any access from an account will only be granted with a valid token, so it is vital that this token be kept secret and only be shared with those you trust. All sorts of ...
    • Account Plans
      TagoIO offers three Account plans that you can choose from to take advantage of the best tools for your application. Select your plan on the My Billing page. A certain limit of Services are already included in your Plan. For more details about the ...
    • Managing your account with the TagoIO Mobile App
      The TagoIO App is your gateway to streamlining your ecosystem and manage all your IoT applications in one place. It allows you to monitor and control your services and resources for all your profiles. Receive real-time notifications and alerts on ...
    • RESTful API
      We provide a powerful set of Restful API documentation that's used by Analysis behind the scenes to perform all sorts of requests to TagoIO, such as but not limited to: Creating, deleting and editing devices Creating, deleting and editing ...
