Common Billing issues
Why was a charge declined?
Declines can happen for a variety of reasons that are determined by the cardholder's bank. Each bank has a system that takes into account various signals, such as the cardholder's spending habits, account balance, and card information like the expiration date and CVV/CVC security number.
Since these signals are constantly changing, a previously successful card might be declined in the future.
Even if all of the card information is correct and the cardholder previously had a successful payment, a future charge can still be declined by a bank.
Finding out more information about a specific decline
TagoIO shows all the information we receive from the cardholder’s bank and the payment processor about a decline in the error message, therefore we don’t have specific information as to why a charge was declined.
If the card information (card number, expiration date, CVV/CVC) is correct but there is still trouble checking out, the cardholder needs to contact their bank.
The cardholder's bank is declining the charge and sending the error. Therefore, only the bank knows why the transaction was declined and how to correct the issue.
Error Messages
“Your card does not support this type of purchase."
  • Some debit cards require a PIN to be entered. If the cardholder is using one of these cards, they'll need to use another card to make the purchase.
  • Some cards have restrictions on international purchases. If the card was issued in a country other than where your business is located, this might be the problem. In this case, the cardholder needs to contact their bank.
  • Some cards (often corporate cards or FSA cards) can only be used for certain business categories, like travel or healthcare.
“Your card is not supported.”
  • Some payment processors restrict card brands (i.e. Discover, Mastercard) based on the country your store is located in. For example, Stripe currently doesn't support Discover cards in Canada.
  • The cardholder needs to use a different brand of card that would be supported for the country where your store is located.
  “Your card has insufficient funds.”
  • The cardholder's bank is saying that they don't have enough funds in their account to cover the costs of the purchase.
  • Sometimes cardholders banks don't properly assess the risk of currency conversion of purchases. If they see that the purchase is in a different currency the bank will decline the charge as insufficient funds so the currency conversion or the currency conversion fee doesn't overdraw the account.
  • If a cardholder sees this error message, they should contact their bank.
    • Setup Billing
      To setup your billing, just go to the top right menu (just under your avatar) and click on Billing. Once you are inside the My Billing page, select the Billing Information tab in order to fill in the company name, address, and any other information ...
    • Billing Summary
      You can get an overview of your account's costs for the current month by clicking on the Summary tab. This view helps you to track the cost of sub-accounts (profiles) that you may use to bill your own customers. This page is composed by three views: ...
    • Payload Parser Troubleshooting
      When using the Payload Parser on TagoIO, you might run into some common problems that stop the parser from decoding your device data correctly. This means the data won't be saved on TagoIO. These problems are usually related to mistakes in how the ...
    • Analysis Overview
    • Downgrading Plans & Services
      You can schedule downgrades in your account for your plan, service limits, and add-ons. If you change your mind any time before the end of the billing cycle, you can modify or cancel the downgrade. All downgrades are only effective at the next ...
