Related Articles
Refund Policy
If you have forgotten to cancel your plan or have decided to cancel it, you may be eligible to receive a refund. TagoIO offers refunds in certain situations. In order to initiate the process, if you are entitled to the refund, follow the steps below: ...
Common Billing issues
Why was a charge declined? Declines can happen for a variety of reasons that are determined by the cardholder's bank. Each bank has a system that takes into account various signals, such as the cardholder's spending habits, account balance, and card ...
Network Integration
Your devices can always connect directly with TagoIO API using HTTPS or MQTT protocol. But, you can also connect them using different protocols to databases and web services by using one of this methods: Create a script that initiate access to ...
Tags System
Tags are a flexible and powerful way for organizing and labeling your assets within TagoIO, allowing you manage access and identify key components such as Devices, Actions, Analysis, Dashboards, Users & Access rules. Operating like key-value pairs, ...
Sending Data to Device
TagoIO supports two-way communication with all your devices so that it can send and receive data. There are some options for you to send data from your application to the device. Among the methods, you can use: Publish to MQTT Post data to a ...
