Data Storage
Data Storage
Data storage is related to the variables stored in the data buckets that are fed by the devices. Each register is composed of a variable and all metadata associated with it. The data storage limit will define the maximum storage capacity for the selected Profile at all times.
You can see the number of registers stored in each data bucket by accessing the tab 'Variables'.
As the field 'location' that contains lat/lng is part of a variable, you can consider location in the same register. The rule applies to metadata as well.
Therefore, in the example below, all the fields and metadata stored with the variable 'temperature' are counted as only 1 register.
    "variable": "temperature",
    "value": 71,
    "unit": "F",
    "time": "2019-06-30 01:58:11",
    "serie": "1561859891862",
    "location": {
      "lat": 35.770723,
      "lng": -78.677328
    "metadata": {
      "color": "green"
If the Data Storage limit is exceeded, no data will be saved until the limit is increased or the number of registers is reduced. API response will indicate that the limit was exceeded for that Profile.
Another simple example: Your device sends speed, temperature, and humidity with location every 1hour. As a result, 3 new registers will be added every hour.
TagoIO will send warning Emails to you each time the storage exceeds 80%, 90%, and 100% of the limit.
More information about examples and FAQ can be found on our Pricing Page.
    • Deleting Data
      DEL - https://api.tago.io/data Headers: Authorization: Your device token. Optional Query Strings KEY TYPE DESCRIPTION query string pre-defined by Tago qty string Maximum number of data to be returned start_date string Start date end_date string end ...
    • Getting Data
      HEADERS: Authorization: Your-Device-Token GET - https://api.tago.io/data QUERYSTRINGS: KEY TYPE DESCRIPTION variable string || array Get variables query string pre-defined by Tago qty string Maximum number of data to be returned. start_date string ...
    • Data Export
      You can download data from your buckets using one of the available formats. Go to the list of Buckets, and click on the 'Export Data' icon located on the top right. Select the format of the file you want to download: CSV XLS JSON XML You can select ...
    • Sending Data
      A device can send data to TagoIO by using the POST method. POST https://api.tago.io/data KEY TYPE REQUIRED variable string [max 100 characters] yes unit string [max 25 characters] no value string/number/boolean [max 6kB] no time string no group ...
    • Data Output Service
      One transaction of Data Output is counted for each register read from a data bucket. Learn more about Getting Data. You need to define the Data Output limit per month for each Profile where your applications are running. Here is one example: a device ...
