Deploying Applications
Watch this video to learn how to work with TagoIO to deploy your solution easily.
When you are ready to scale up your application, you can create scripts to automate the device registration, the dashboard creation, and the association between devices and users.
Also, by using the option 'Bulk Devices Upload' you can create multiple devices by uploading a .csv file.
    • Creating a Sandbox
      Sandbox refers to an isolated testing environment that enables developers to run applications without affecting other applications that have critical devices or users connected.  Use sandboxes to test new applications with the confidence that they ...
    • How it works
      There are a few things that you need to know about how TagoIO works in order to optimize your applications. Watch this short video to learn about the concepts around devices, and tokens.
    • Profiles
      Profiles are similar to having different sub-accounts under your own main account. You can create multiple profiles for persons or organizations and then share them with others. By doing this, you will continue to own the 'sub-account' while allowing ...
    • Services Overview
      TagoIO offers a broad range of services that can be allocated the way your applications needs it to be. By provisioning the services that each Profile will use throughout the month, you will know exactly how much you will be charged. You can ...
