Grouping Dashboards
Grouping Dashboards
You can group related dashboards using dashboard tags. To do so, go to “Dashboard”, click on the gear icon to edit it, then on the section “Tags” create a new tag. After that, on the section “Group dashboards using Tags” select the grouping tag.
To create sub-levels you just need to repeat the above procedure for each level. It is possible to create three grouping levels.
After this, the dashboard will be grouped in the sidebar. The grouping criteria uses the key and value. If you delete a tag and that grouping has sub levels, the sub-levels will be removed as well.
When you share a grouped dashboard the grouping will be shown on the shared account’s list of dashboards.
    • Grouping variables
      Grouping variables It is expected that most devices will send more than one variable at a certain time. And when visualizing the data, the user may want to see them synchronized at each sample period. For example, a device sends a GPS location, speed ...
    • Sharing Dashboards
      A great feature from TagoIO is its native sharing capability for dashboards, because we know that sometimes a dashboard can become an entire feature that you want to share. If you want to share only the template of your dashboards, use the Distribute ...
    • Distributing Dashboards
      You can share a template of your dashboard, without any of your data, and send a link to anyone to add a copy to their account through a customized install page. After that, they will be able to modify the dashboards as they wish. When people access ...
    • Downlinks using Dashboards
      Learn how to perform downlink for Class C or A devices using Analysis. Also, we will show how to send downlink data from dashboards. This approach can be used in the following cases: For devices with class C: to immediately send a downlink message to ...
    • Dynamic Table Widget
      Dynamic tables are tables that dynamically populate as your data arrive while keeping the history of the previous data in each row. Editing the dynamic table It is possible to customize widget color, apply a formula to columns, show time column, show ...
