Uploading Files
Uploading Files
To upload a file using the admin platform, go to Files and click on  on the top right corner of the page.
By default, all files will be uploaded with Public access. This means that you can copy the file's link to easily share it with someone.
Remember to always set your files to Public if you plan on using them inside widgets.
Drag and Drop
If you do not wish to manually select the files, you can drag-and-drop them into a specific folder or into the main panel.
Folders
Folders can be created before you upload your files. Simply press the button on the top right corner, or right-click in an empty space and then select New Folder.
After you select the desired files, they will be uploaded to the current folder being viewed. If you wish to upload the files to another folder, simply access that folder and upload the files there.
If you uploaded the files in the wrong folder, simply select all of them and drag-and-drop them to the correct folder, or right-click them and select the option Move.
    • Files
      You and your IoT devices can send and receive files such as images, csv, txt and many other file formats, and all of these files can be stored and accessed at TagoIO. Overview Files storage is commonly used to send and receive files from devices, ...
    • Device data management
      The device page provides tools for visualizing, filtering, editing, importing and exporting variables, facilitating the management of data received by your device. You can access these tools by navigating to the Device module, selecting a device, and ...
    • Analysis Overview
    • Deploying Applications
      Watch this video to learn how to work with TagoIO to deploy your solution easily. When you are ready to scale up your application, you can create scripts to automate the device registration, the dashboard creation, and the association between devices ...
    • File storage service
      You can use our Files module to store any type of files for reports, videos, logos, background images, and more. The File service is measured by the overall size of all files stored in your profiles. If any of your profile reaches the limit of size ...
