Embedding Widgets to your website
Embedded widgets are a powerful feature if you want an easy way to display your data from Tago in another application. By generating the embedding code on a widget, you can add it to your website, or any other application.
Below is a simple example of using embedded widgets in your own website.
To generate the embedding code, go to the dashboard that has the widget you want to embed, and click the gear icon on that widget.
Now, go to the tab Embed Widget, and click on Generate Code.
Tago will generate the complete frame for you to embed this widget in your website, and then you can click on copy. Add this code to your website, and the data from Tago will be updated in real-time for anyone to see.
Related Articles
Widgets Overview
Dashboards are composed by widgets that can display and collect data from users. TagoIO provides a variety of widgets to handle your data in real time. The available options cover from simple dials to tables, maps, videos, and even forms that you can ...
Creating Keypad Widgets
This article will demonstrate how to create a Keypad Widget using the TagoIO Node.js SDK. In order for you to create keypad widgets, this is the structure that you will need to send to the account.dashboards.widgets.create method. { "analysis_run": ...
Geofences in map widgets
Geofences allow developers to color parts of the map and determine events in specific areas. To create a geofence, go to Geofence options in your widget's configuration. Then, set the option Allow users to edit geofence to yes. You can choose to ...
Sens'it with Sigfox
TagoIO is fully integrated with Sens'it v2 and v3 devices by providing the perfect integration with Sigfox backend and parsing the data by extracting the measured variables in real-time. Sens'it + Sigfox + TagoIO Connectivity DiagramAll data sent ...
Tile Widget
Tiles allow you to simplify how users interact with your dashboards by providing a more intuitive and beautiful set of options. Use Tile to display clickable images that will redirect user to another website, dashboard or tab. Creating your own To ...
