Yabby parsing location payload
Hi!
Please help me to parse payload from Yabby Edge lorawan tracker which connected to TTN. I can't do it myself I don't know javascript.
21:30:42:
Raw payload:
[ { "variable": "ttn_payload_v3", "value": "{\"end_device_ids\":{\"dev_eui\":\"0016C001F001BF5F\",\"device_id\":\"yabby1\",\"application_ids\":{\"application_id\":\"digital2\"},\"join_eui\":\"70B3D57050000009\",\"dev_addr\":\"260B90AD\"},\"uplink_message\":{\"frm_payload\":\"xw6T0v3mDwEEVgE=\",\"f_port\":89,\"f_cnt\":26,\"session_key_id\":\"AYEQOCVt3tvN/Xoz1SfBMg==\",\"decoded_payload\":{},\"rx_metadata\":[{\"gateway_ids\":{\"gateway_id\":\"shaxr2107\",\"eui\":\"A840412198984150\"},\"time\":\"2022-05-29T16:30:42.469557Z\",\"timestamp\":1283021795,\"rssi\":-69,\"channel_rssi\":-69,\"snr\":11.2,\"uplink_token\":\"ChcKFQoJc2hheHIyMTA3EgioQEEhmJhBUBDjt+XjBBoMCLK/zpQGEPvT9IYCILjdu9CrnwIqDAiyv86UBhCIvvPfAQ==\",\"channel_index\":1}],\"settings\":{\"data_rate\":{\"lora\":{\"bandwidth\":125000,\"spreading_factor\":7}},\"coding_rate\":\"4/5\",\"frequency\":\"868300000\",\"timestamp\":1283021795,\"time\":\"2022-05-29T16:30:42.469557Z\"},\"received_at\":\"2022-05-29T16:30:42.552470935Z\",\"consumed_airtime\":\"0.061696s\",\"locations\":{\"frm-payload\":{\"latitude\":2.2414337,\"longitude\":-174.4830459,\"source\":\"SOURCE_GPS\"}},\"network_ids\":{\"net_id\":\"000013\",\"tenant_id\":\"ttn\",\"cluster_id\":\"eu1\",\"cluster_address\":\"eu1.cloud.thethings.network\"}},\"correlation_ids\":[\"as:up:01G48AFMJ66C9CTPT1WMENPG8Y\",\"gs:conn:01G4812DKVPPWFGVVRN5PR5DNW\",\"gs:up:host:01G4812DM60WN2KV9NTRKBDZTJ\",\"gs:uplink:01G48AFMBQZC2FJDY7J8MSXXVE\",\"ns:uplink:01G48AFMBREWZ8WPD4T1ZD4Y6A\",\"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01G48AFMBR30NF639N3FDH552P\",\"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01G48AFMJ5BM782VM1HJ8RYDS7\"],\"received_at\":\"2022-05-29T16:30:42.758234590Z\"}", "group": "1653841842838" } ]
[ { "variable": "ttn_payload_v3", "value": "{\"end_device_ids\":{\"dev_eui\":\"-------------\",\"device_id\":\"yabby1\",\"application_ids\":{\"application_id\":\"digital2\"},\"join_eui\":\"70B3D57050000009\",\"dev_addr\":\"260B90AD\"},\"uplink_message\":{\"frm_payload\":\"xw6T0v3mDwEEVgE=\",\"f_port\":89,\"f_cnt\":26,\"session_key_id\":\"AYEQOCVt3tvN/Xoz1SfBMg==\",\"decoded_payload\":{},\"rx_metadata\":[{\"gateway_ids\":{\"gateway_id\":\"shaxr2107\",\"eui\":\"A840412198984150\"},\"time\":\"2022-05-29T16:30:42.469557Z\",\"timestamp\":1283021795,\"rssi\":-69,\"channel_rssi\":-69,\"snr\":11.2,\"uplink_token\":\"ChcKFQoJc2hheHIyMTA3EgioQEEhmJhBUBDjt+XjBBoMCLK/zpQGEPvT9IYCILjdu9CrnwIqDAiyv86UBhCIvvPfAQ==\",\"channel_index\":1}],\"settings\":{\"data_rate\":{\"lora\":{\"bandwidth\":125000,\"spreading_factor\":7}},\"coding_rate\":\"4/5\",\"frequency\":\"868300000\",\"timestamp\":1283021795,\"time\":\"2022-05-29T16:30:42.469557Z\"},\"received_at\":\"2022-05-29T16:30:42.552470935Z\",\"consumed_airtime\":\"0.061696s\",\"locations\":{\"frm-payload\":{\"latitude\":2.2414337,\"longitude\":-174.4830459,\"source\":\"SOURCE_GPS\"}},\"network_ids\":{\"net_id\":\"000013\",\"tenant_id\":\"ttn\",\"cluster_id\":\"eu1\",\"cluster_address\":\"eu1.cloud.thethings.network\"}},\"correlation_ids\":[\"as:up:01G48AFMJ66C9CTPT1WMENPG8Y\",\"gs:conn:01G4812DKVPPWFGVVRN5PR5DNW\",\"gs:up:host:01G4812DM60WN2KV9NTRKBDZTJ\",\"gs:uplink:01G48AFMBQZC2FJDY7J8MSXXVE\",\"ns:uplink:01G48AFMBREWZ8WPD4T1ZD4Y6A\",\"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01G48AFMBR30NF639N3FDH552P\",\"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01G48AFMJ5BM782VM1HJ8RYDS7\"],\"received_at\":\"2022-05-29T16:30:42.758234590Z\"}", "group": "1653841842838" } ]
