X-Axis Timestamp Not Matching UTC-5 in Line Chart Widget
Dear Support,
I’m located in Lima, Peru (time zone UTC-5), and this setting is correctly configured in my Tago account. I'm receiving the timestamp properly formatted as part of the payload. I've created a dashboard using dynamic table and line chart widgets to display and visualize temperature and humidity readings.
The issue is that, in the line chart, the X-axis (which should show the timestamp) does not reflect the UTC-5 correction, even though this time zone adjustment has been set in the widget's properties. I need your support to resolve this issue.
To speed things up and allow you to see the problem directly, I'm sharing access to my account. The dashboard experiencing this issue is named "Monitoreo de Temperatura & Humedad".
Regards
CM
