On this tutorial, I’m going to show how you can change addresses on your Dynamic Table widget.
This feature is very useful and could optimize your work. Let’s follow the steps below:
You will need to create the Dynamic Table widget as usual, and in the User Control tab you will need to activate the Allow users to edit this variable button, and on the Field Type, you will need to select Address.
Then click to save it. I’m going to use the Device Emulator to send data to the location variable.
This data will be displayed on the Dynamic Table and you will be able to edit it, selecting a new address.
After you change the address, click save.
it’s done.
We already have this feature on the input form, the configuration is the same, try it!
I hope you enjoyed this tutorial, see you!
