Update in the PDF Service Generator!
Greetings everyone,
We are deactivating our old PDF Service Generator (https://pdf.tago.io) and replacing it with a new one https://pdf.middleware.tago.io.
If you are using the old PDF Service Generator, please be sure to make the necessary updates by August 22nd, 2022, when the old system will be deactivated.
The process of updating is quite simple; you have to change the old URL for the new one and set the analysis-token. You can learn more about it in our documentation.
If you have any questions or need help updating your application, please contact our support by opening a ticket, and a TagoIO team member will assist you as soon as possible.
Thank you!
