Unable to set variable from Button Widget
Hey All.
I have been working on getting a downlink example working with a dashboard. I have run into an issue with the push button widget.
I am using the dragino LT-22222-L on the helium network and the default parser.
I have chosen the ro1_status variable, which has two states that are defined by strings:
OFF
ON
I have tried updating the two button states to reflect this, but get an error when I save saying "There are fields that need your attention!" and highlighting the options areas.
Is the issue that I am setting a variable that is already set by the device? This is a status variable. I want the button to update based on this status and run an analysis when I press it.
Caio
