[SOLVED] Unable to edit Device List field
I have a Blueprint dashboard using the Device List widget. I'd like to allow the user to be able to edit the values for one of the columns. This column is associated with a device parameter. Allow edit is enabled for the column.
The existing device parameter value is displayed, but it can't be edited.
Any ideas?
