TTN Plugin Error
TTN Plugin Error
Hi all,
I have a problem with receiving data from the TTN into TagoCore.
The sensors used are Dragino LHT65, so I have installed the belonging encoder.
In the Tags section i have added the key "serial" and the dev. eui as a value.
I have attached screenshots for reference.
Can someone assist with this error code?
Thanks for your help!
Daniel
