Trigger update on device parameter change
Greetings,
On our Blueprint Dashboard, a user can change a device parameter via the Device List widget. We use device parameters in combination with variables to visualize device and system info.
Is there a mechanism to automatically trigger an update (e.g. start an analysis) when one or more device parameters are changed? Actions allow you to trigger based on variable updates but not with parameters. Perhaps there is another way?
