Hi all, i have an issue occurred now that my analysis is more complex:
Error: timeout of 60000ms exceeded
at createError (/home/catinotm/node-server/lora-analysis/node_modules/axios/lib/core/createError.js:16:15)
at Timeout.handleRequestTimeout (/home/catinotm/node-server/lora-analysis/node_modules/axios/lib/adapters/http.js:252:16)
Just after 60sec since the starting of data processing i saw the above error.
Have you any suggestion about it? Can i increase the timeout in anyway?
