When creating a dynamic table, enabling the time columns allows the following color conditions to be set:
This works great, but unfortunately only affects the “Date and Time” column:
If I try to do the same setting for Address, it will say “your variable” instead of time:
Is there any way to use metadata or any other method to color code other variables by age as well?
