I have Tagocore installed and running inside a Raspberry pi3.
The Integration with Tago-IO is running smoothly.
I need to work with the data inside Tagocore and for that I'm using a script invoked by the "Action" function, and this "Action" is also working.
At the moment I use the following support to access tagocore data through the script (
https://tagocore.com/docs/analysis/code)
This document points in its script an example of accessing the TAGOCORE_DATA environment.
My data array follows the proper model suggested by Tagocore/Tago-IO.
PROBLEM: Executing the script returns an error in the Analysis console.
This is the Scope data which is being sent by the device, the token of this device was place in the environment variable of Analysis
"variable": "temperature",
"value": 16.5
"variable": "humidity",
"value": 74
This is the suggested script:
const data = process.env.TAGOCORE_DATA;
const temperatureItem = data.find((i) => i.variable === 'temperature');
console.log("Temperature is at:", temperatureItem.value);
The error returned is:
[2022-09-30 16:27:01.564]: Finishing script execution with code 1
[2022-09-30 16:27:01.552]: /home/pi/Users/tagocore/project-code/calculo_01_edit1.js:2
TypeError: Cannot read property 'find' of undefined
at Object.<anonymous> (/home/pi/Users/tagocore/project-code/calculo_01_edit1.js:2:30)
at Module._compile (internal/modules/cjs/loader.js:1085:14)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
at Module.load (internal/modules/cjs/loader.js:950:32)
at Function.Module._load (internal/modules/cjs/loader.js:790:14)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
at internal/main/run_main_module.js:17:47
[2022-09-30 16:27:01.062]: Starting analysis 6140e438ed59eb1f99dc68f0
Finally:
If I run the script separately elsewhere without the line (const data = process.env.TAGOCORE_DATA;) it works correctly and returns the following: ("Temperature is at:" 16.5)
I would really appreciate your help from the community.
