Greetings everyone,
If you haven't heard yet, we have just published the public beta version of TagoCore!
This migration note is here to help ease the transition between the last TagoCore version (0.2.0) and the public beta version (0.3.0).
If you already executed TagoCore v0.3.0 in your machine and you had plugins installed, you may have seen the message:
"Failed to start Plugin <XYZ> - Not compatible with this TagoCore version, only compatible with ~1.0.0"
Plugins from the last TagoCore version are no longer compatible with this version, and due to a structural difference, we had to republish all plugins under a different ID. This means that no plugin will automatically update to their newest versions.
If you wish to remove this message from your terminal, you have to manually delete the plugin folder located in the `Plugin Folder` setting on TagoCore.
If you wish to use the MQTT plugin, Raspberry Pi plugin, or Freezer Simulator plugin, simply download the version 0.3.0 of the desired plugin.
Let us know if you have any questions!
