If your application have a form widget with several fields, this may be driving users away from the application or confusing users with too much information. You can easily solve this problem setting the visibility configurations.
With the Visibility feature the fields of the form are shown based on previous selections.
Check out this widgets with and without visibility configurations bellow:
The right side, with visibility configurations is much cleaner right?
Try to implement this feature on your application.
And if you have any questions, reply to this post and I will be happy to help you!
